EQmeat
One of the usual suspects
One of my Snell JII has a Seas H334 8 inch woofer that no longer responds. It tested as infinity on the Ohmmeter. I read about a proceedure in which you cut out the cone. Taking off the foam surround and then cutting the spider away near the basket. At this point you should be able to access the voice coil and possibly resolder the tinsel lead back on to it, depending on what you find when you get in there.
Has anyone here duplicated this procedure? Can a spider be glued back together after it is cut entirely out of the basket?
