duncan
flâneur in training
A few months ago I posted about picking up an inexpensive broken Yamaha CDC-585 and getting it to work. I'd wondered from the start about replacing op-amps in its analog section, but that turned out to be just part of what it's been subjected to in the meantime.
I'll be posting a sort of "recipe" later with pictures and a list of locations and parts (mostly capacitors), but until I get those pictures taken I want to mention the loading drawer belt issue.
As some besides myself have noticed, it can be hard to find replacement belts that are a good match for the OEM part unless you're willing to do some measuring and fudging. This model uses Yamaha part VQ776900, but apparently Yamaha no longer supplies it, and if you look for it on Amazon or That Auction Site, what you are most likely to find are knockoff suppliers who will provide a belt of the correct length but only a 1 square millimeter cross section. Because it lacks the right surface area, it won't transmit as much torque as it should, which is important for moving that big 5-disc drawer around. It probably won't last very long either. Being short of wit, I ordered bad belts from two different Chinese vendors, each time having to wait for the proverbial Slow Boat to deliver those little envelopes of disappointment.
Here's a reliable replacement: part SBM4.65 made by PRB ("Projector Recorder Belt") Corporation. In their nomenclature SB is "square belt," M is a thickness code, and 4.65 is the full length in inches. And there's a seller on That Auction Site who provides SBM4.65 in bags of four for a pretty reasonable price.
According to service manuals, all of the following Yamaha changers use the same loading belt:
...clears throat...
CDC501, CDC502, CDC505, CDC506, CDC555, CDC565, CDC575, CDC585, CDC600, CDC655, CDC665, CDC675, CDC685, CDC697, CDC900, CDC901, CDC902, CDC905, CDC906
Edited to add Ghetto Tip: if you have one of these players with a slipping or broken loading belt, and you've already started down my path and bought a subpar replacement, one short term strategy is to swap it with the belt that raises/lowers the optical pickup unit. It's the same part, but that belt doesn't have as tough a job, so maybe it has some life left in it.
...clears throat...
