Been working on getting a blown up Yamaha M-60 up and running after another shop butchered it. Fairly easily got the amp section all worked out as I've done a few now and it's pretty much always been the same parts blown in each.
This one, though, was probably the 2nd worst I've seen from a butchering standpoint as it was missing transistors.
But anyway, onto the main thing I learned, apparently TO-3P packages can fail as a short between the collector and the screw hole. I guess the plastic isolation isn't that thick, but it's just a bizarre thing to see. I had gotten everything sorted out, popped on the DBT and had a nice bright light. After messing around for a bit I thought I just had a short at my insulator since it is possible to accidentally screw through them with the metal screws Yamaha used. After I thought I had it sorted out and no more bright DBT it was time for full power.
Unit worked nicely for about an hour unit I heard a nice pop and saw a decent amount of smoke. Transistor had shorted from rail to chassis... Upon testing the transistor actually still tested good, but when mounted to the unit it it was showing a dead short. Decided to test the screw hole for continuity and found that it was a short from collector to screw on one side of the hole. One other transistor in the power supply section was behaving similarly, and upon testing I found it also had a partial isolation failure.
I guess I got extremely lucky because nothing actually blew from the short, (or maybe that's just how it is since the collector is the input voltage).
But anyway, I guess my lesson is that I shouldn't trust that a TO-3P transistor that tests good but was messed with by someone else is still good. Goes to show you never know what kind of history the unit you're dealing with has.
