Though clearly not a Sansui-specific topic, as my non-speaker gear is essentially all Sansui, I believe this forum works.
When disconnecting boards one from another, there are some wires/ribbons that have connections. Often times ground wires have no such connectors and are simply soldered in place.
In certain situations, like the C-2102 in process now, there is a post with a wrapped wire and multiple leads soldered from the post going to various other locations. Other grounds simply appear to be soldered in a convenient spot.
Seeing there 'might' be an occasion where I screwed up (!!) or simply wish to make an update later, it seemed to me that I should add connectors to these wires. This greatly facilitates future removal.
I appreciate this is non-factory, but at least a practical approach to the situation.
Also, given that there is next to no vibration or moisture issues, as in an automotive environment, I do not see any downside to this approach, besides the extra time needed to install the connectors.
I am interested in knowing how others treat the re-connection of such wires during their work.
