I just talked to the fellow I work for about the Quickie interconnects, and we both agreed that they were great sounding cables, but that Mike is somewhat spotty in getting them out...he also felt like I do that the WW stuff is a must audition cable at that price point.
There's also a difference in construction...the Quickies are OK, but in a decent homebrew sort of way...the WW's on the other hand, look like they cost five times what the Quickies do, just as you would expect something from a professional cable manufacturing concern to appear, the fit and finish is that much better...
To comment on Number 6's comments about Nordost, yep, I've played with Nordost cables, from the Freys to Valhallas, to Blue Heaven, Red Dawn, Moonglow, etc., and they are clear, bright, clean, the Nordost family sound is just that...the farther up the line you go, the fewer compromises the sound is subjected to, but none of them are warm...they are also a lot less immune to outside interference than many other types of cables...also, the better cables use the WBT Nextgen type plugs and you can really hear their vast superiority in clarity in comparison to the Neutrik ProFi's used on stuff like the Red Dawn, for example...
I tried a set of Valhalla Bi-wires on my Martin Logans and a couple of sets of the interconnects to hook up the SACD player and preamp to amps when I brought home a set of NuForce Reference monoblocks for an audition....the Valhalla speaker cables acted like an antenna broadcasting all the digital noise from the amplifiers and the interconnects acted like receiving antennas, it was impossible to use any FM tuner in the house with this setup!!!
So, I don't know the particular RFI conditions at the OP's home, but if there are long runs to the amps I would be wary of noise pickup...
Another incident was when I was setting up a table one Saturday and needed to test one of the little Bellari tube phono preamps, so I grabbed a set of Nordost Frey 1m interconnects to go between the ProJect Xtension I was seting up and the Bellari...Man! The hum was incredible through a set of Sennheser 650's plugged into the headphone jack...I really like the Frey's sound, but in this instance they plain flat did not work!
I futzed around with it a bunch and was unable to get the hum to disappear...until, that is, I grabbed a set of interconnects I had made up for the bench using Klotz cable I cut off Rega arm I rewired with an Incognito kit and some salvaged Neutrik ProFi RCA plugs...instant silence...
That one incident reinforced the fact that you MUST audition cables in YOUR system with YOUR equipment before really deciding what you're going to spend your hard earned cash upon...
Which is why we send out cables all the time to folks to audition...it's really the only way to buy stuff that you KNOW is going to work well for you...
