Hello all,
I'm new to this forum and need some help with a DCD-1500 II I just purchased on eBay.
It was listed as working, but when I tested it, it did not even spin the disk and the display shows zeros and nothing else.
It loads the disk, spins a couple of turns and nothing more.
From the discussions above, it seems that the laser does not find the first track, so no information can be retrieved from the disk.
I opened the top cover and found that a round magnetic puck that sits on top of the clamp is loose and not sure if it is suppose to be like that, or it got dislocated during shipment.
Actually, I don't know what is it's purpose, it acts like a weight perhaps to keep the disk securely loaded.
Other problems I'm seeing is that the laser does not park to home position after the CD is ejected, this basically makes locking for transport impossible.
To lock the laser, I have to push the laser back and then I can lock it with the screw on the bottom.
When I talked to the seller, he told me that he will lock it before shipment and the screw was in the locked position, but perhaps it did not lock, so that might explain why it is totally broken now.
Any help to figure out what's going on, will be very much appreciated.
Thanks
Thanks
