Thank you! I did in the end
Mr. Kevin said that:
- He uses a Teledyne Stripall thermal stripper. Despite silicone not melting, apparently heat does do it's magic regardless, and it works for him just fine.
- Mechanical variety, he recommended the Jonard ST450 - it's the same one as CK 330009.
- His manufacturer also told him that nicking with a razorblade and pulling with nails can work; but it didn't for me - maybe I'm too clumsy
Superflex has an outer insulation jacket of silicone - I described my attempts at melting that insulation in
post #3 above. Wire is lacquered Litz underneath, and for that tiny a wire, a bead of flux on the wire + a bead of solder on the tip of my iron work perfectly as a "solder pot" for melting Litz lacquer and tinning the wire. It's stripping the outer, silicone jacket, that is presenting a problem.
Yes! I tried one of those - on Mr. Kevin's recommendation as well (except that the variety seems to be called Jonard ST450 - same stripper, different name).
It operates on a principle of two closing blades with V-notches and a fixed stop adjustable to wire gauges to control the opening between the Vs.
Basically, a very fancy "quick adjust" version of these:
I originally was super excited for it; but it seems that it wasn't good'nuff. The blades are coarse ground (they aren't mirror finish); and with silicone being super squishy, instead of cutting it, they squish it. The three settings that were close enough for the wire - 30, 32, and 34 - we all not too good. 30 would work ~50%, 32 would nick or rip out 1-2 strands, and 34 would rip out a few strands and nick the remaining strands.
My final solution to this adventure was this.
- I did buy a thermal stripper for the future.
- But for now, I spent ~15-20 minutes adjusting the Klein manual stripper above to a setting where it will reliably rip the silicone; and not damage the wire. See, because - unlike CK and Jonard - it's *infinitely* adjustable, I was able to dial it just so where it'll reliably strip (by - admittedly - ripping, rather than cutting, the insulation off) w/o damaging the strands.
My strands' damage test BTW involved inspecting the insulation "straw" that was taken off to make sure there aren't any ripped strands inside, and pulling back the remaining insulation a bit to make sure there are no nicks or damage around the rip line.
My resistance checks are also good and check out (re-wired the head with the newly stripped wire and proceeding to the assembly).
Thank you all who chimed in guys!
