A previous owner (likely a recording studio) re-wired my MC2105's Input Coupling switch, I can't fathom why.
Any ideas?
The input blocking capacitors (C1, C2 0.22uF mylar) are removed.
In "normal", the input signal passes directly to the input board (the wires from the input jacks are soldered to the wires to the input board, directly on the switch, as seen)
In "direct", two things happen: (1) L&R inputs are shorted together, and (2) L&R 4ohm autoformer outputs are shorted together (note the red wires).
(Note they also soldered the ground & 8 ohm outputs directly to speaker wire ...)
For reference, here's how it's supposed to look (credit to this YouTube video):
And here's the original circuit:
Any ideas?
