Symptom: Left channel is distorted, but only when the speakers are selected and connected.
Test 1 settings: Headphones plugged in; 8 ohm speakers connected to Main speaker terminals.
Speaker knob to Remote / Off: No distortion through headphone left channel
Speaker knob to Main / Both: Distortion through headphone left channel & distortion through left speaker
Test 2 settings: Headphones plugged in; no speakers connected
Speaker knob to Main / Both: No distortion through headphone left channel
Other measurements / diagnostic work done:
DC offset under 10mV both channels; DBT dim (to confirm OPTs are OK)
Swapped L to R inputs from Tone Amp, distortion remains in left channel (isolating problem to amp)
Swapped L to R speakers, distortion remains in left channel (eliminating a bad speaker as a cause)
De-oxited Speaker knob (to eliminate dirty contact as a cause)
Repairs done thus far:
Re-flowed many solder joints
Confirmed all transistors on the tone board are operational
De-oxited all the pots & switches
Re-capped power supply, power amp, tone control, and equalizer boards (the channel was totally out before the re-cap and no, I didn't re-cap it thinking it'd solve the channel being out, I wanted to eliminate bad caps as a possible cause before repairing the channel)
Next steps:
I imagine I could start swapping components L to R on the amp board, and see if I get lucky.
Any ideas???? It seems like the additional load of the speaker may be causing something to clip? I don't have an oscilloscope so can't look at the signal but it sounds super distorted, like a radio station with bad reception.
The patient:
The circuit diagram, tracing the headphone & speaker signal wires (if helpful):
Next steps:
The patient:
