My brother's old AV receiver sounded great ... but had a buzzing hum coming from the speakers which became noticeable at really low volumes.
The buzz remained the same volume and pitch regardless of input, volume, input mode, etc. It was present via headphones as well.
https://youtube.com/shorts/oPqB4l6L3po
I have a sound spectrum app on my phone, here's what it showed when held up to a speaker:
And for a control, what it showed with the sound off:
So, pretty clear spikes at ~200Hz and then every 200Hz above (400Hz, 600Hz, 800Hz, 1kHz, 1.2kHz).
My first thought had been a smoothing cap going bad or something else in the power supply, but I thought that the buzzing should have been 60Hz if that were the case.
Here's how it looks under the hood:
So I started with simple stuff, wiggling components that might have bad solder joints, making sure grounds were all in place.
Lo and behold, tightening this screw ground connection on the PS board immediately eliminated the buzz!
There we go. Fixed! Somehow the loose ground was causing that weird 200Hz-resonant buzzing through the outputs. Learned something new.
Not that complicated, but maybe this'll help someone out in the future with the same issue.
