some cr-820 questions
painttoad
i am a toad
hi, i am going thru a cr-820 and have some questions:
1st: fr701/702. what wattage should these be replaced with?
i've seen 2 suggestions by guys that i trust:
i ordered the 1/4 watt but am doubting my choice after reading more on the unit. i have not removed or measured the original yet.
2nd: i have replaced tr 609/610 and tr707/708 and tr801 - tr809.
replaced all electrolytics, trimmers, relay on the main board. i have all diodes but have not replaced any yet. dc offset is around 5mv. idle current is stable @7mv.
is there any true benefit to wholesale transistor replacement on the amp board like was done here?:
i'm all for replacing for reliability but i'm also a fan of letting sleeping dogs lie.
phono stage,tone board have had all transistors and 'lytics replaced.
the unit sounds great and measures to spec(as far as my capabilities go that is)
3rd: has anyone been able to mod the tuner to raise the muting threshold?
i watched a video on the unit and the one on the video exhibits the same 'issues' that this one does. granted, i am in a basement with only a dipole antenna but stations that i receive in stereo on other units with no antenna will not get past the muting circuit in the yamaha with an antenna.
i plan to haul it upstairs to check reception but have not gotten to that point yet and wanted to ask first.
that's all for now, i may have a few other questions.
thanks for reading and any input.
  • Like
Reactions: mbz
Not aware of any problems in this area, working off the schematic and hopefully agreeing with the FR's marking, 68ohms, 85mA gives
0.5W (= I x I x R)
Looks like a sensible selection criteria, psu and possible troublemakers.
I wouldn't but it comes down to what you are going to do with the amp, perfectly ok to retain OEM transistors if you plan to sell, it will be fine for years to come. If you plan to keep then yeah, understandable that you go a little overboard but then include C0G type ceramics and...
1N4148's are cents so I'd replace the 1S1555(?) wouldn't bother with rectifier diodes unless you've had preious success of soft recovery/no recovery/UF?...
