bonzoro
Swill Bucket
Those look sweet.
Thanks, when I get a spare minute, I'm going to wire the high end to my 700 WOPL and drive the bottom end with my 400 WOPL.
Those look sweet.
Found a place on the rear center panel that reads R84 on each of them. But that's it. I don't see anything that looks like a serial number.Here is what the site says. Get the flashlight,
From 1948 though 1961, Klipschorn's had the serial number stamped into the tailboard, woofer access door, or inside the woofer chamber. They are there, even the Heresy's had em stamped in addition to the sticker. Check the bottom i think that's where the access panel is. You'll find it.
the serial number should be stamped in the top center of the rear panel the goes up against the wall and also somewhere by the crossover
If the tag is missing, it should be stamped in the wood near the crossover, often in the edge plys.
You were correct I found the on the edge of the ply. TY
Thanks. I have to close in the left side of the left speaker because there's no wall there. For everything else, I'll use gaskets because it's the original design. I assume there's a reason they didn't enclose the backs from the beginning.
Guys, I'm a bit confused.
I assume the foam isn't needed here (the circled segment) because that edge doesn't contact the wall. Is that correct? I assume so because the other examples don't show any foam there.
But the part that perplexes me is this. Why is there no foam in the side sections circled below? They definitely contact the wall. Is it because that's where the sound radiates through the screen?
It seems that even when one finds one's summit set of speakers, there are yet hills to climb. Right now, I'm happy as a clam with them as is -- with just over 8 feet separation, my walls 2 x 6 construction. Heck, one speaker isn't in a corner (just up against the common wall) and still they sound fantastic. I don't seem to need perfection.Max extension from these comes from (a) solid wall construction (think plaster & lath, block/brick) and (b) a large room. If you have gypsum + nothing interior walls, it doesn't much matter how well you seal them--bass will go through the wall. Many people only have one decent corner. We know that is often at odds with interior considerations, but, acoustically, it's worth moving things to use corners (or making something reinforcing to help). Get 6 feet of decently solid corner in a room with 10 ft ceilings even with zero foam and you'll smile like a little kid. BTW, I've used the enclosed rear method out in a room and it's no substitute for stiffer wall construction. There are many examples of custom solutions if you search a bit (and we can help if you come-up short). Find the faux corner sheet and maybe pwk's "half room principle" paper.
Thanks. Your post makes me smile.Love it. Didn't mean to come-off all downer, was just trying to put an unsealed 2" of khorn in a different perspective. We get it, the clam bit (I just cranked some decently recorded piano)Smiling both with and for you.
Yes, the room's far from perfect and will remain that way. I've pushed my wife far enough. She wants the couch on that wall. She wants the book shelf next to the speaker between it and the other couch. We got rid of one book shelf to make space for this thing. She's not crazy about the way the one on the left sticks out into the room. She's made major accommodations for me. And they sound great. She's an amazing person, truly one of the best I've ever known. Not just to me but to everyone. She's a brilliant psychologist. She cares deeply about people. She's a phenomenal mom. If she didn't like these KHorns enough to ask me to sell them, I would. Music is incredible but I'd find another way to enjoy it.Many people, probably even most, don't put near enough work into getting the room right as they do shuffling gear; myself included. That said, I don't do near as much shuffling as I used to, but still haven't really put any work into the rooms.
Don't need foam at edge of grill, that's in the mouth of the horn. The other places where foam is are intermediate parts of the horn path which you want to seal as best you can. I had my Ks for years (decades) before I did this. It made an improvement. Earth shattering no but an improvement nonetheless.Guys, I'm a bit confused.
Thanks. I sealed mine and didn't notice much improvement. Not that it needed improvement. Even with one side of one speaker open, they sounded great. Sealing that open side made a discernible difference in bass output, though the cabinet maker friend who was helping me, who's also a music lover, didn't think even that change was necessary. I agreed; not necessary. The room acoustics seem to be working well with the KHorns. But he had cut this gorgeous piece of cabinet grade plywood for me. Stuff one can't get at normal hardware stores; it's all special ordered. I saw no reason not to screw it into the side of the speaker and I'm glad we did.Don't need foam at edge of grill, that's in the mouth of the horn. The other places where foam is are intermediate parts of the horn path which you want to seal as best you can. I had my Ks for years (decades) before I did this. It made an improvement. Earth shattering no but an improvement nonetheless.
I hear ya. How high is up? If I'm already really happy with something, is it smart to keep probing for ways to improve things further? I have to resist those sorts of temptations, which I have too. The Jubilees are so large, there's no way they'd work in my house. Not unless I really want to be single again. They might physically fit but they'd look silly and the room is almost certainly too small for them to sound good. Plus they'd cost a #$%@ing fortune, as they've not been around for very long. Not going in that direction.I didn't think I needed more and cleaner bass until I heard Jubilees....YMMV. And then to kill that buzz I heard DaveA's S-MWM.
UG jubes?Too small to sound good? You need to talk to Roy
Mine are the UG jubes ...homey could not afford the current ones either.
The tailboards on mine taper inward at the bottom. Yours appear to run straight down.View attachment 3418683
I use the pipe insulation on the bottom of the tophats (as others have indicated); and rubber garage door seal on the tailboard, as seen here ^^. I used wider seal than this, but I live in a very old house that is far from square.
Underground Jubilees. The original, professional, active iteration sold by Klipsch from about 2007 to whenever the current home-use Jubilees were sold.UG jubes?
These aren’t mine. The tailboards are pretty standard.The tailboards on mine taper inward at the bottom. Yours appear to run straight down.
