Some one out there
joekid
Well-Known Member
With all the posts on the QRX 9001 restoration.Someone had to replace this relay,Omron MH4P 24vdc.I have looked at all the past posts that I could fine an came up empty.We no it is a 14 pin relay.Am hoping someone did fine one to replace there's , so they can tell me were to go.Take care all
Joe
Am still in need of this Omron MH4P-0 relay that is on PCB board F-2634 an F-2636 on my QRX 9001 .I have called emailed and am failing on my quest to fine just two of these.Anyway thanks for looking and take care
Joe
Just curious, but are you sure the relay is bad? Have you checked to see that you are getting 24 volts at its primary?
Yes the relay is bad,I have cleaned the points.She has worked for a yr.I have email Bob so far he has not gotten back to me.Thanks Rob and Cademan for your time
Joe
