dastinger
Member
That's precisely it! They used the STK3062 as the pre-amp section and it seems like the signal does, indeed, come from that board on the front. Also, I noticed how the last stop before leaving that board is the Muting feature which does not work very well. Sound still goes through when Mute is enabled so I'll definitely start with that board on the front. I'll check all the caps and solder joints. I'll also check the transistors while I'm at it and decide whether I'd like to replace that STK. It's a really cheap part on eBay so why not.Doesn't look like the amp has a separate preamp board - everything is on the P701 main amp board. I'm a little confused by the fact that it has an STK3062 hybrid power IC, which feeds what appear to be the output transistors. Maybe they used the STK as a preamp, I'm not sure. But if you look at the schematic, you'll see that WS04, which appears to be the main signal, comes from the front panel input selector board, and feeds the STK on P701.
Unfortunately, this receiver does not have a Tape In or else I'd feed the DVD player into it and see if that STK was bypassed. There is a DAT In and Out, but I'm not sure that works the same way as a regular Tape In and Out.
Any other ideas of how to proceed?
Thank you so much for all your help so far!
