**Something very odd **
Newjin
So I have a marantz 2245 in vary good condition and sounds great.
No issues with sound and different channel.
Now I just noticed this when I'm on aux with volume nob at zero turned all the way off I get a vary quiet fm station coming from my speakers I was up close ( ear right to my tweeter ) inspecting the sound.
I noticed that it goes away in phono but tape and aux I can hear it slightly vary vary quiet.
When I start to turn up volume i can hear both at super low volume playing at the same time but once I turn it mm it goes away or at least get over powered by the song playing on my laptop.
Has anyone ever had this issue which obviously is a symptom of something else happening electronically.
Thanks in advanced for any involvement in this thread
Is the FM station you are hearing the same station the FM tuner is set to? I think all of the tuner boards are still powered when the Selector switch is on Aux or Tape.
I'm not sure how much cross talk between sources is typical on a 2245.
Some receivers cut power to the AM/FM sections when they're not selected to avoid that. If you have something of low impedance (or shorting plugs) in the AUX or TAPE, the slight feed-thru might go away.
Thanks I just didnt know if there was something wrong mind you I would have never noticed if I wasn't inspecting for crackling at low volume.
I just didn't understand what was happening or causing it. Thanks for your input runningdog
Much appreciated
Thanks it did end up going away after a short while
Thanks conradh
