Rex Aeterna
Gigolo of Gigolos
hey just wondering what's wrong. it's very odd. if i use speaker b outputs with anything my amp gets hot real quick. i noticed this last night when i played my speakers and left channel was distorting and i started to smell something so i clicked off right away and unhooked everything. luckily nothing actually happened to the amp itself and still perfect working order....that is if i use only speaker A output section. i can run everything perfectly fine through speaker A outputs and the amp will run nice and cool. only if i even attempt to use speaker B it get hot insanely quick.
can't check anything as of now since my multi-meter has blown fuse. just wondering if anyone can make an educational guess right off the bat to know what the problem possibly can be? it was serviced as well about few months ago and had it's dc offset and bias adjusted to specs and so forth if anyone is curious.
