Together with a friend I am busy building a phono board (he does the technical side , I do the ‘listening’ part) .
This print is built into in a control amplifier. Technical measuring of this print is quite right (if we hang it on a scoop with signal generator), but at the moment we have this board and power supply built in into the preamp, lower frequencies are more present than the rest of the sound spectrum and it sounds veiled (does not sound very open).
Other sources connected to the same control amplifier (eg CD player) and the same set of speakers sound good though. Nice open sound and a balanced sound across the whole frequency range.
The turntable connected to another (integrated) amplifier, which has a built-in phono stage, with the same set of speakers sounds fine too.
It is difficult to communicate about sound, but does anyone know what the above sound experience can explain (ie the closed sound and the emphasis on lower frequencies)?
The built phono amplifier is based on Op Amp Applications Handbook (Analog Devices Series) / Topology Considerations for RIAA Phono
Preamplifiers by Walt Jung.
http://www.analog.com/library/analogdialogue/archives/39-05/op_amp_applications_handbook.html
Section 6, pages 6-24
Also attached the technical schematics (and meausurements diagrams) of the RIAA preamp.
