supwiddiss
Member
Hi all. Long time!
By fluke accident, or luck! Sent to Sony after online chat and a phone call to a dude who's only concern was "Is it still under warranty?". Go figure.
Read this stuff. Anyone who can assist, please step up. I understand there are only 4 types of HDMI cables. So which one did I ponder upon??
To Sony support:
Hello,
I have discovered by accident that a particular HDMI cable will prevent non-Sony input peripherals from corrupting BRAVIA Sync.
Since purchasing my Sony Bravia television and Sony audio system a few years ago, I have been unable to use a DVD Player, and more recently a satellite set top box because doing so would disable the audio system's ability to produce sound from those speakers. Audio would only come from the television speakers and the audio system would not respond to commands from the television remote control. This was found upon connecting HDMI-only from input peripherals to the television AND ALSO trying the same to the audio system.
My equipment:
Sony KDL-46HX850
Sony HT-CT150
Sanyo DVD Player
Satellite Set Top Box
Apple TV Gen 3
I have read all of your support articles and have attempted EVERY SINGLE suggestion multiple times. I have tried multiple combinations of suggestions, have made every possible system software setting changes in an attempt to get the audio system to maintain communication and synchronization with the television. In every single instance, connecting an input device to either TV OR audio system HDMI port would within 10 seconds deliver a message to the TV stating "Audio System Disabled".
With exception of the Apple TV. This device has never interfered with television/audio system Bravia Sync. Audio has always been able to be produced from the audio system using a television HDMI Port (currently Port 4). Apple TV can also be attached to any HDMI port on the audio system and sound can be reproduced from it, provided the proper input on the audio system is selected.
Since purchase I have NEVER been able to use a DVD player on this Sony combination. I have a Sanyo TV with Sanyo/Panasonic sound bar audio system and sound is reproduced on the sound bar flawlessly. Such is the operation with the satellite receiver. All connections are through the HDMI input ports on the Sanyo television.
I have discovered today that using the included short (1 meter) HDMI cable included with a replacement satellite receiver that my Sony equipment will operate correctly and audio is ALWAYS REPRODUCED CORRECTLY with the HT-CT150. Television remote control operates the audio system perfectly. Also, I attached the Sanyo DVD player to the same cable and once again the audio system operated perfectly. Apple TV worked on the same cable as it always had, perfectly.
WE NEED YOUR ENGINEERING STAFF TO DETERMINE WHAT HDMI CABLE TYPE WILL CORRECT "HIJACKING" OR CORRUPTION OF THE SONY BRAVIA SYNC AND ARC PASS THROUGH WHEN ATTACHING DEVICES THAT ACTUALLY DO THIS TO THE COMPONENT CONFIGURATION.
Since purchase of my Sony TV/Audio System combination I have used high quality HDMI Cables manufactured by Belkin and Monster Cable from between 1-1.5 meters appx. Cables are marked High Speed or Ethernet with High Speed with gold plated contacts. In the above description, sync is corrupted every single time devices are connected.
The "cheap" STB HDMI cable is marked High Speed HDMI With Ethernet. It has no manufacturer marking on it. It is most probably of Asian origin, perhaps from China. This is the only cable that I have found that allows the Sony electronics to operate 100% flawless.
As mentioned, I have used television input ports other that the default port 1 ARC to connect the audio system. Confusion and frustration of resetting the TV settings/sync settings upon detaching the problem peripherals was and is solved by a simple and pure luck cable swap.
Can your Engineering staff determine the exact type of cable which your customers can obtain to solve a very frustrating issue that many (as listed on forums in many web sites, and Sony) have experienced for quite some time now?
I have had Sony AV products for many years. I still own a Sony mini TV purchased in Europe in the early 70's with USA/PAL/CCIR options. So, I'm not exactly ready to give up just yet! Unfortunately I purchased a Sony LCD projection TV which developed a defective optical block which gave a green picture. It was not covered on a global solution under Sony supervision and the optical block was removed and cleaned by me. I am an EE with over 25 years experience with electronics and Amateur Radio.
To Sony support:
Hello,
My equipment:
Sony KDL-46HX850
Sony HT-CT150
Sanyo DVD Player
Apple TV Gen 3
