Inflataballz
Hello Everyone,
I recently found a Sony car Discman (D-152CK) in an old drawer, I plugged it in with it's power suppluin and it turned on, however, when I try to make it read CDs the disc spins and it appears "00" and then "no disc" in the LCD screen, after that message is displayed the disc stops playing inside .I tried plugging it in with speakers and headphones but i heard nothing but the beeping sound effect that plays when I press the "play" button. Sometimes when I try putting in CD it starts spinning normally but it does nothing and when I try to skip from track 0 to 1 it starts spinning very slowly and no sound comes out. I strongly believe the issue with this particular device is the laser, which is probably dead after more than a decade but I might as well be wrong in assuming this. I also tried moving the laser mechanism back then put in a CD turned it on and I noticed that when I turned it off and opened the tray, the laser mechanism had moved back to it's original position which is closer to the center. My experience with fixing optical disc players is very small, so if anyone could clear things up or recognize a known problem i would be very thankful.
