Greetings one and all. I picked up a Sony DTC-75ES and it would not play or record. I replaced the rotary gear and now it attempts to play and record. I say ATTEMPTS because it goes through the motions of playing or recording.
At first I got no sound on playback. Then I cleaned the heads and I get some sound on and off now. It sounds somewhat distorted then it is clean audio then silent and so on.
So I am wondering if it is the tape that I am using. It is not a true DAT tape. It is a Imation DAT72 data cartridge tape. I have seen someone use these tapes on youtube on this exact same deck with no problems.
I also heard from another source that the data storage tapes are a thinner tape.
So do you think this is a tape issue or something with the head itself on the deck, seeing as how I started hearing distorted audio after cleaning head?
Many thanks
Christopher
Many thanks
Christopher
