xchg.ca
Hi guys, got Sony DVP NS900V player for cheap in thrift store. Main idea is to use it as SACD player and ppl also mentioned that audio qualities are pretty good as well as it is quite tweakable.
BUT after testing it at home I've discovered that it plays CD, DVD, DVD-R, DVD-DL and DVD-R DL well
But in same time it fails to recognize HD layer in hybrid SACD
Unfortunately I do not have HD only SACD to test all my SACDs are hybrid.
I have performed an aliment/calibration procedure with CD, DVD-SL, DVD-DL successfully in service menu
- still no success! Calibration with hybrid SACD as DVD-DL failed though ( not sure if this supposed to work at first place )
I am a bit puzzled, as I thought that if DVD-DL is works fine - SACD should as well - as it uses same laser!? Right ?
Any ideas and suggestions I can try?
Thank you
Thank you
