Sony mini disc player
Bertoli
My MDS JE 320 is shot and I have 1000s discs, and no equipment to play them. I wonder if there is a member that could fix this equipment, including the servo part wich I think is one of the things that went wrong. Thank you very much..
No parts support, so it is unlikely to be repairable. I just had a Sony Minidisk player in and all it needed were 3 microswitches which were no longer available, and they had special, long plastic actuator arms so nothing else could be retrofit. I won't work on them anymore. Sony used to be great with parts support, no more.
I believe I have one that works. I'll bring it in and try it. Ping me in a couple days and I'll let you know. I hope this is not forbidden, but you can have it for shipping if it works.
Cool move regardless of outcome.
I have two decks, though I must admit they sit idle.
I'm playing it now. It was VERY dusty. Just need to make sure eject and other exercises work properly. And I have the remote. I never lose remotes. I'm weird.
Usually, on my two, there are belts that fail.
It's a snap with some of those jeweler's tools to replace them, and they're available. Fixed both of mine this way.
I also have several decks and only ever needed the belts changed. I have a Yamaha that won't record anymore but plays fine.
I've got a stack of portables and a couple cd-md machines. Only one portable has a bucket of bolts left of the bearings the rest work just fine right now.
