Hello all!
I was very lucky to find a Sony N77ES, mutivoltage, European Version (4 caps), in great working condition and visually almost perfect. Apart from the heat on the right side and a very low bzzz, also coming from the right side I never got any problem in these 4 months .
Yesterday, I was installing a new power distributor and the system was on but not playing music, when connecting the powered Subwoofer on (not connected to the N77ES, but in the same triplet AC outlet), I heard a noise on the left speaker.
Some moments later I looked at the N77Es and it was off but switched on the switch button. It was an immediate panic situation.
I decided to open it and found the fuses on the board that connects to the AC outlet, the bottom fuse was blown. I bought new fuses and replaced the blown one and the upper good one. Powered the amp up and the bottom fuse blown again - i could see kind of a little lightning on the fuse when the fuse blown.
I installed a new fuse and disconnected the cable from the transformer to the main board and switched the amp on - it made the protection check and did not blown the fuse.
When connecting the cable again the fuse blown again.
What could this be? Any easy fix or something that a non experienced on electronics could try to solve?
Even if I find a good technician for this it will be a pain to take it 3 floors down without an elevator... apart from the repair cost.
Please help and advice.
Thank you very much
Carlos
Thank you very much
Carlos
