PoPSiCLe
I have a relatively newly aquired PS-LX510, with a genuine Sony cartridge, with NOS Sony stylus. It works pretty well, everything moves as it should, but I only get sound out of one channel.
I've measured the cable from the internal board, that is fine. I've also measured the sockets for the pickup to the board inside the tonearm assembly, those seem fine. I haven't yet measured the cable from the tonearm assembly to the internal board, but I doubt that is the issue, as that cable is fairly high gauge, and unlikely to break internally.
I read the info thread, https://audiokarma.org/forums/index...x510-lx520-lx55-lx57-knowledge-thread.748374/
And there someone commented that they had a similar problem, where the tonearm sockets didn't form a good connection with the pins from the cartridge.
Is that the most likely solution? I was hoping not having to strip the tonearm assembly, but it seems I might have to, unless anyone has something else worth trying before.
I have ofc tested a different cartridge/stylus, and swapped right/left on the amp. The problem follows the swap.
