ha11oga11o
Hello all,
i have many issues with Sony PS-LX7. It turns, locks speed, buttons are responsive. But tonearm is not moving because belt is stretched. Size light is not on also. Does it stay on always, or its shut down when its not needed? Main problem is that cant lower arm to touch record. Does anyone know, have same unit, have any idea,... does it lower tone arm with mechanism which is moved with that belt assembly.
Somewhere i read that it can be used manually if belt is not on, but no one mentioned rising and placing down arm. Can it be that mine unit stuck in some spot that does not allow it to go further down?
Also, for me its almost impossible to find belt, so i need quite time to order it from abroad.
If anyone has service manual to share, that would be great also.
Any thoughts, ideas or whatever could help. Thank you in advance.
