bandwagoner
Hello All,
I have a Sony PS-T22 Turntable that I've been using for about the past year. I seem to be getting a little bit of static noise out of the left channel; it sounds like the ground isn't attached properly, but there is no ground wire to attach! The noise is faint, but annoying. It slowly goes mostly silent if I move the tonearm off of the record and place it on the resting mount. The noise gets louder if I move my hand toward the cartridge, and it's very loud if I touch the cartridge.
I'm assuming the ground is internal or something? I'm very new to this so I would appreciate some advice on adjusting it.
Also, I'm using an Audio Technica AT95E Cartridge, and the stylus seems to be stuck to the right side, as if it was bent or something, although it still gives great sound. I have a feeling that I must adjust some settings on the turntable such as the counterweight and others, but I have no idea how to start learning what settings are good for my cartridge/turntable. If anyone has any tips on how to properly adjust those things I would be very grateful!
Thanks in advance for your help!
