Sony PS-X7 Automatic Function Help
zuhmuguh
I have a Sony PS-X7 turntable that runs fine as a manual, but recently I wanted to try and restore its automatic functions. Before my repair attempt, the table would not automatically cue, would only occasionally automatically return at the end of a record, and touching the start/stop button mid-operation would not stop the platter. After reading every pertinent thread on AudioKarma about PS-X6/X7 repairs, I went in and degreased all of the gunked up parts and regreased with white lithium. While I had the machine open, I also applied DeoxIT where I thought it may have been needed.
Upon putting it back together, it seemed like the cleaning had worked: the auto cue was working (albeit dropping in to the wrong spot), and the auto return worked as it should have. I followed the service manual's guide to adjusting the drop-point, however I think my screwdriver bumped into another part while I was trying to make the adjustment. Since then, all automatic functions on the table are no longer operable, although it does run fine manually.
I was hoping someone on here may be able to help me out! My theory is that I may have nudged the brake drum/shutter assembly out of place, but I'm not quite sure what position it should be in. If anyone could provide a picture, that would be fantastic.
It is quite likely the Record Size Selector Lever has split and no longer shifts the attached linkage. When this lever splits (plastic splits along the securing set screw) the auto start drop down point will be way out of whack from the record size selected. See page 12 of the service manual for a description of this part. This lever is on the PS-X5, 6, and 7 models.
Hey, thanks for the response. The record size selector linkage actually seems to be in fine working order; I made sure to examine it because I know it can cause problems with this series of turntables. The problem with wrong drop point was due to me installing the brake drum/shutter assembly in the wrong position: I fixed that and managed to get one successful cue and auto return out of the table. However, the START/STOP button still will not stop the platter once it gets going, any ideas?
I've managed to fix this, and I think I'm almost in the clear. There's one final problem: I'm hearing a clicking when the platter slows down after play. Anyone know how to fix this?
Hello Zuhmuguh, did you manage to fix the clicking sound? I have a PS-22 that does exactly the same. Thought I would ask you before I delve into it!
Cheers
Mike
Zuhmuguh posted 3 times in 2016 and hasn't been seen on this site since August 2018 ... so I wouldn't hold out much hope on an answer from him. Sorry I don't know the answer to your question.
I had a similar problem with my PS-X7. The start/stop was intermittent to get the table started (even with a licked finger ;)) Once it started it would happily play along in fully auto mode as long as I allowed it to play, but the same problem occurred when I went to stop to change LPs, using the start/stop button. The table would not stop without completely powering down. It would click during these episodes as well. I assumed it was at least partially a old seized lube problem so I sent it to my tech for a cleaning & lubrication. That did not eliminate the problem, it was a bad IC in the motor. I luckily found a new/used motor on line and now if functions beautifully.
You may note that I've got an issue with what year it is, LOL!
So far the PS-X7 I'm working on right now doesn't have any clicking occurring, and it stops when you press the start/stop and when the cycle completes. Getting it to start is another matter .... but I understand that cleaning the contact plate inside the capacitance switches usually solves this. The record size selector seems to work and the auto-functions do as well, but I haven't pulled the front panel out yet to see if that selector is cracked. The brake drum collar on the tonearm is cracked, so I'll have to deal with that. The strobe isn't lighting up, but looking at the board, the capacitor C106 is leaking so hopefully replacing that will get the neon to light up.
Good thread here: https://audiokarma.org/forums/index.php?threads/sony-ps-x7-speed-problems.797152/
on all the X5, X6. X7 series the grease used to lube the auto return mechanism dries out and becomes like glue.
if you disassemble the mechansim and clean it, then relube much of the issues will be solved. Just be sure to take tons of pics and make small sketches as you disassemble. otherwise you will create a 100x problem when you try to put back together and dont remember where all the parts went.
This is excellent advice! I thought about cleaning and re-lubing the table myself. One after about 30 minutes of assessing the complexity of the return mechanism, I took it to my faithful tech. It was the best $60 I ever spent! I could see about 50 ways to put it together out of synch. For those who cleaned and re-lubed the PS-X7 successfully, you have my eternal respect! :bowdown:
Tuve un problema similar con mi PS-X7. El inicio/parada era intermitente para poner en marcha la mesa (incluso con un dedo lamido ;)). Una vez que arrancó, tocaba felizmente
Tuve un problema similar con mi PS-X7. El inicio/parada era intermitente para poner en marcha la mesa (incluso con un dedo lamido ;)). Una vez que arrancó, tocaba felizmente en modo totalmente automático siempre que le permitiera tocar, pero el mismo problema ocurrió cuando fui a detenerme para cambiar los LP, usando el botón de inicio/parada. La mesa no se detenía sin apagarse por completo. También hacía clic durante estos episodios. Supuse que era al menos parcialmente un viejo problema de lubricación agarrotada, así que se la envié a mi técnico para que la limpiara y lubricara. Eso no eliminó el problema, era un IC defectuoso en el motor. Afortunadamente encontré un motor nuevo/usado en línea y ahora funciona de maravilla.
_Hola gracias por tu respuesta, tienes algo más de información como alguna foto de que IC estaba defectuoso ( mi Sony al conectar el power en ON y presionar el táctil Start se pone en funcionamiento, pero el táctil stop no funciona (en alguna ocasión muy esporádica después de insistir mucho si detiene al pulsar stop pero 1 entre 100 o 200 pulsaciones , muy desesperante), para detener tengo que pulsar power en OFF entonces el brazo se eleva y vuelve a su reposo y se detiene el giro del disco.
*pero aquí empieza otra odisea cuando vuelvo a pulsar power en ON al pulsar el táctil "Start" este no responde entonces desconecto power en OFF al dejar pasar varios minutos
*Cuando se conecta power ON el plato actúa de dos formas diferentes
1⁰ al pulsar táctil "Start" el motor empieza a girar con normalidad pero el táctil "stop" sigue sin funcionar
2⁰ después de estar desconectado por unos minutos al pulsar power en ON (sin pulsar el "Start") el motor empieza a girar con normalidad encendiendo el led del pulsador "Start"
*Nota Al estar el motor funcionando si pulsamos el táctil repetición (este funciona siempre que se pulsa conectando y desconectando la función repetición tantas veces como se quiera, estando encendido el led Start/stop y el motor girando), luego para detener el giro del disco hay 2 opciones 1⁰ desconectar la función repetición y dejar que el brazo llegue al final del disco activando el retorno del brazo y manteniendo el giro del motor, la 2⁰ opción es desconectar el power en OFF que activa el retorno del brazo y detiene el giro del motor.
** Al volver a conectar "después de unos minutos o incluso al día siguiente" el power en ON el "Start" funciona ocasionalmente y el stop no funciona
¡Es un consejo excelente! Pensé en limpiar y volver a lubricar la mesa yo mismo. Después de unos 30 minutos de evaluar la complejidad del mecanismo de retorno, se la llevé a mi campo técnico. ¡Fueron los 60 dólares mejores gastados de mi vida! Podía ver unas 50 formas de volver a armarla sin sincronización. Para aquellos que limpiaron y volvieron a lubricar la PS-X7 con éxito, ¡tienen mi respeto eterno! :reverencia:
_aqui has gastado los mejores 60$ sin quebraderos de cabeza, esa también es una buena idea
