Sony PUA-237 owners: cartridge recommendations?
JMC79
I recently picked up a Sony TTS-3000A in incredible condition for the shockingly ridiculous price of $20. I’m quickly falling in love with this table and planning on making it my primary. It’s equipped with the PUA-237 arm and I’m looking for recommendations on a cartridge. It has the original Sony headshell which is a nice bonus.
Also wondering if anyone has info on the serial numbers? Wondering when this one date from serial is 50426
Thanks in advance for any info!
Looks a very nice catch. Cartridges can cost anything from a few tens of dollars to hundreds or thousands. Do you have a particular budget in mind?
It seems that the arm was originally fitted with an MC cartridge but you could go for an MM.
http://www.thevintageknob.org/sony-PUA-237.html
Do you know the effective mass of the arm? This helps in recommending a cartridge, although I would imagine this arm to be medium-mass or higher.
Thanks for the reply,
Only info I’ve been able to find is that it’s “moderate to high mass”
As for what I can spend I’d like to keep it under $300.
In that case, you should go for a medium-compliance cartridge - you choice will be quite wide in this category. If you're going for an MM cartridge, I'd recommend that you look at the Audio Technica AT-VM95 range - perhaps the AT-VM95ML with MicroLine stylus, which is particularly good value. If you want to take a step into MC, the Denon DL-110 would be a good candidate - this is a high-output MC cartridge that you can use with an MM phono-stage. I suggest you take a look at the reviews of these cartridges.
Dang. Nice score!
If you haven't already picked up on it, that upper right corner of the frame is removable so the arm has room to move. The original TTS-3000 was made to use with the longer PUA-236 arm.
The 236/237 are supposed to be very nice arms that are kind of overlooked these days. Sony, overall, is still kind of overlooked as a high-end manufacturer, though they still continue with their habit of making bleeding-edge stuff that they don't really advertise, while also making much more visible electronic equipment at every price point imaginable. Most of the other Japanese electronics companies created separate hi-end brand names for market differentiation. Sony is just...weird.
