Bill Ferris
Lunatic Member
Your HDMI to S/PDIF converter likely cannot handle a DSD stream. If anything, you'll get the PCM layer output in stereo to the S/PDIF output. Worst case, no audio at all passes through.
FWIW,the convertor/extractor`s specs indicate: Digital output, as follows LPCM2.0/ DTS/Dolby-AC3, which mirrors it`s HDMI input specs. and also indicates 192kHz sampling rate.
When I used it in the past I used it to extract my OPPO, while watching BR/DVD`s HDMI audio to feed my 20 yr.old Sony stereo receiver, after running it`s S/PDIF coax output to a DAC at the receiver for decoding to L/R analog to feed the receiver so to provide better quality audio in my car garage versus the TV`s internal speakers ..
The HDMI feed to the Garage`s Flat screen was/is a 5.6 Gig HDMI wireless receiver.
That setup/configuration provided much better SQ in that situation, as would be imagined over the thin sounding Flat screen`s internal speakers.
I decided to just use the Flat screens RCA analog outputs to feed the Sony receiver later on, so that HDMI to S/PDIF/TOSLINK convertor became available, hence my thinking to experiment with possible SACD extraction from it`s coax
output.
But if you say it can`t/won`t work, then I won`t waste my time trying.
Thanks for the reply/information, benricci
