icehawkfin
Does anyone know what's the biggest difference between these speakers? Would they couple together well if I wanted to use both pairs for all channel stereo? It's my personal preference with my receiver at the moment as I feel "enveloped" by the music whereas 2 channel stereo just feels less "wide". I know that pairing with exactly same model would be optimised but I'd have chance to grab E70's and I'm tempted to see how this model sounds. If they don't pair well, I'll just do some testing by interest and keep the other as spare set (in case I end up buying the pair)
So, I have SS-G1s and I'm kinda interested in pair of SS-E70s on the side of them.
Dimensions and speaker terminal sizes seem quite identical. Isn't both of them made in Germany by the way (or at least part of them if I recall)? Some comment I came across claimed "E70 was step down from G-series" yet all specs seem very similar to me as is their looks.
Does anyone see or know major differences and to which model's advantage? Was G1s more expensive than E70s originally? Couldn't find much info or user comments especially on the part of E70s.
SS-E70 according to: https://www.radiomuseum.org/r/sony_carbocon_speaker_system_ss_e70.html
- Wave bands
- - without
- Power type and voltage
- No Power needed
- Loudspeaker
- 3 Loudspeakers
- Material
- Wooden case
- from Radiomuseum.org
- Model: Carbocon Speaker System SS-E70 - Sony Corporation; Tokyo
- Shape
- Console with any shape - in general
- Dimensions (WHD)
- 310 x 610 x 280 mm / 12.2 x 24 x 11 inch
- Notes
- Sony 3-Way Speaker System Model SS-E70.
30 - 20000Hz, 8Ω, 91 dB/W/m
65 Watt Sinus, 100 Watt Music
Volume 33 litres
Drivers:
1x Bass 250mm Cone type (Carbocon Membran)
1x MidRange 80mm Cone type
1x 20mm Tweeter soft dome type
Crossover Frequencies: 1000Hz, 7000Hz
Detachable Front Grille
Optional:
Speaker Stand Sony WS-E 70
- Net weight (2.2 lb = 1 kg)
- 12 kg / 26 lb 6.9 oz (26.432 lb)
- Mentioned in
- -- Original prospect or advert (Sony Catalogue)
- Wave bands
- - without
- No Power needed
- Loudspeaker
- 3 Loudspeakers
- Material
- Wooden case
- Model: Speaker System SS-G1 MARKII - Sony Corporation; Tokyo
- Shape
- Dimensions (WHD)
- 340 x 595 x 300 mm / 13.4 x 23.4 x 11.8 inch
- Notes
- Sony 3-Way Speaker System Model SS-G1MARKII (2).
32 - 20000Hz, 8Ω, 91 dB/W/m
Volume 37 litres
Drivers:
1x 25mm Tweeter soft dome type
Crossover Frequencies: 800Hz, 4000Hz
Optional:
- 13 kg / 28 lb 10.1 oz (28.634 lb)
- Mentioned in
- -- Original prospect or advert (Sony Catalogue - Audio 1981)
