Sony ST-S700ES - incorrect frequency displayed
Bagpuss
I've obtained an old Sony ST-S700ES quite cheaply.
It's all working well, as far as I can tell, except that the frequency displayed is a little 'off' - for example, a station on 92.90MHz will only lock on when the tuner displays 92.95MHz.
This +0.05 MHz offset is constant throughout the FM band.
I had a look at the service manual to see if it had a simple way to 'trim' things to display the correct value, hoping there'd be a pot or something that would adjust it, but I can't see anything obvious.
The FM adjustments there include "Phase Locked Loop Detect Adjustment", "Muting Width Adjustment", "IF Distortion Adjustment", "FM Stereo Separation Adjustment", "FM Meter Level Adjustment", "FM Muting Level Adjustment", "Pilot Cancel Adjustment", "CAL TONE Level Adjustment", "SST Circuit Adjustment", "Tracking Adjustment", "Control Voltage Adjustment" - but none of those sounds quite the ticket?
I have no test equipment, or to be fair any knowledge of tuner calibration... I can live with the inaccurate display but if there's a quick fix...
Without test equipment and knowledge on this you could make things worse. Alignments should be done in their entirety. Muting, separation, Meter level, Pilot, and Cal tone, wouldn't affect this. The other adjustments can.
In the end, I decided to try a little trial and error - adjusting the various coils slightly, then trying to return them to the original position if they made no difference.
It was the Phase Locked Loop Detect Adjustment that did the trick (IFT207), and the tuner now shows the correct frequency.
