Darkvalley
Member
Hi
Well, short-lived joy following the discovery of this amp found this morning.
Functional, various conclusive tests (including speaker suicides). I turn off, disconnect, and install an antenna to test the FM, and then nothing.
Apart from putting an antenna, I haven’t touched anything.
The symptoms:
No more sound except by turning the volume to 3/4 and it "spits" into the speakers (all types of inputs)
The Low Filter button causes the relay to trigger for a fraction of a second.
I suppose, maybe wrongly, a problem with the preamp. Why on earth does the button lock the relay for 1/2 second?
Thank you sincerely for your help.
Kinds rearads
Laurent (France)
The symptoms:
Kinds rearads
Laurent (France)
