Sony STR-6046A
surfnsound
Just sharing this little amp. Previous posts are confirmed:
  • Excellent phono amp (kicked-out my Sansui 771, SX-..., )
  • Rather good FM (I compare to the 771 which is similar, but not as good as my external Leak Stereofetic)
  • Compact bass and open heights, good soundstage
  • Real wood case
I listen on the very nice Celestion Ditton 33, volume is at 10 o'clock, louder would be for party time only. The bad: The knobs are a bit plastiky compared to the Sansuis and SX-650 for example. Still, after 771, 7070, Scott 420 (also very nice), SX-650, SX-6000, Sansui 800, Marantz, Luxman, ... this little guy becomes my main system just because it looks good enough and vinyl sounds best :) Very surprised.
Especially this phono stage sounds the best to me compared to everything I did hear so far (Scott was also very good ! ). Maybe I was just lucky having a good model, but I will not recap, this is so good as-is. Unfortunately FM is not on the top, but good enough, excellent with external tuner.
RvC13gkKhJLyHgZh7
