Hoping for some help with this receiver.
I just picked it up and it's in generally good condition but has an annoying fault:
When running in FM Stereo, the right-hand speaker drops out (volume reduces but 90%) after 10 mins. This is at low-mid volume, so not pushing the unit hard. This only happens in FM Stereo (works fine in Aux and AM), and if I push the Mono button, both channels work fine. As soon as I switch back to Stereo, the right speaker drops.
There's no crackling at all, and it doesn't seem like a faulty switch as far as I can tell.
If I switch the unit off/on again the problem remains, but if I switch it off and unplug it for 10 mins, it will then run fine again for 10 mins.
I've read that it could be related to faulty 330k resistors in the FM Stereo Separation module (R257, R258), but I don't have enough experience to know if this would be the case given it's an intermittent fault. They don't show any obvious visual signs of overheating, and I don't want to pull them out for testing without first ruling out other possible causes.
Any 6800SD experts out there who can help?
