JB8
Well-Known Member
After cleaning pots and pushbuttons thoroughly (and multiple times), I'm still not getting any sound from the right channel via headphones or speaker outs. Cleaning the volume/balance pot increased the output of the good channel significantly, but the right channel is still dead. Right channel will only make a tiny static pop when toggling the speaker selector switch. If I push the balance hard right and turn it up I get a very faint signal, but still only out of the left channel speaker, so a little bleed. In looking at the input RCA's on the back panel I suspect this unit was exposed to smoke, there's some gummy residue present.
(When I got the unit several months ago it had no power cord and a few lights were out, so I'm just now tackling the bad channel)
I've started probing and checking voltages, etc., including the STK amp mods where I'm getting some significant variances across the two channels. The left channel matches the schematics fairly closely, but the right channel is producing some wonky numbers. I can provide the voltages if it will be helpful.
Two questions:
1) Should I assume the wonky STK-056 numbers indicate a bad amp module, or could a bad cap or transistor in the PS or amp section be contributing to the numbers?
2) If the consensus is a bad amp mod, there are several replacements available, primarily on the big 3rd party auction site. While I'd love to find a SONY replacement, are there any amp mod brands I should stay away from?
This unit was pretty cheap, it's super dirty still and perhaps not worth further investment, but I'd love to give it a second life. Any assistance here is much appreciated, as always!
Two questions:
