The '7055 has a totally different MPX section. Always best to start a new thread for a new problem.I have an STR-7055 with this same issue. From what I've read online, there's an IC that goes bad and is, unfortunately, unavailable except from scrap units. I'm not sure if the entire STR-7xxx line has this tuner design or not. I haven't investigated it in my unit, but I'll check back here in case there's a solution.
I wasn't asking for advice but merely offering a possible suggestion based on a problem with my unit that also exists in other models of this line. I do start new threads when needed, but thanks.The '7055 has a totally different MPX section. Always best to start a new thread for a new problem.
Doesn't sound to promising, Sorry, I have no other suggestions to offer.While I don't have a big selection of small ceramic caps here, I did find a 40pf and a 120pf. I attached each one individually to the pads in the photo. Each one gave me the same result: 0.0mv on both ends of R309 when tuned to a strong station and it goes up to 3.0mv when in between stations. The red plastic case of the transformer at MU301 is sealed with no adjustments.
No offense intended.I wasn't asking for advice but merely offering a possible suggestion based on a problem with my unit that also exists in other models of this line. I do start new threads when needed, but thanks.![]()
Nope. I still have the stereo though.Hi did this ever get sorted
