Sony STR-7045 Service Help
Glockroomba
Hello Audio Karma crew,
Long time lurker and first-time poster here. I can't tell you all how much you have helped me get my feet off the ground with so many hobbies and projects. I need you all now more than ever as I am tackling my first ever stereo service on my beloved Sony STR-7045. I bought this stereo 5 years ago, and it has been in daily regular use since. From opening the unit up, everything is completely original and this unit has not been serviced in its 53 years of life.
It's in great physical condition, but I noticed a few weeks back that the left speaker seemed much weaker than the right - particularly in the low end. I swapped speaker terminals to see if the weak signal switched to the right speaker, and it did. This prompted my desire to give this stereo the love it deserves and get it working like new.
I am somewhat experienced with building and servicing simple electronics, but nothing of this magnitude to date. By experienced, I mean I have done services like re-caps and biasing on vintage guitar amps, building and troubleshooting guitar pedals and working on guitar electronics. I felt that I had the skills required to diagnose and service this stereo, so I bought a few tools to get me started in diagnosing what exactly was happening. I also built a dim bulb tester to safely verify my work as I went along. Feel free to continue reading as I dive into what I have done so far, what I have found and where I am at currently.
The TLDR version is that when load testing the power amp, I found the right channel was outputting 41.86w while the left was 34.03w. I got hasty and re-capped the power supply board and power amp board, and now it will not pass the dim bulb test. Yikes. More below
As far as tools go, I bought a simple oscilloscope/signal generator combo and some dummy loads to get me started in diagnosing. Here is what I tested:
1. Phono preamp - Signal gen into phono input and output to oscilloscope. Channels balanced - no issues!
2. Aux input - Signal gen into aux input and output to oscilloscope. Channels balanced - no issues!
3. Tape input - I wanted to make sure I tested this since I run my Sansui RA-500 and EQ through the tape output. Same as the previous two tests with no issues!
4. Power amp - I ran the speaker outs to the 8ohm dummy loads and connected the oscilloscope. I realized after taking this photo that I needed to set the Vrms to 10x on the scope, so we are actually seeing 16.5v on the left (yellow) and 18.3v on the right (blue). This was an exciting discovery for me as it solidified that my ears were not playing tricks on me!
After this initial testing, I got a little hasty. Rather than testing all of the components on the power amp and power supply board, I jumped straight to re-capping both of them.
(Side note: I 3D printed these collars so I could re-use the old filter cap mounting hardware.)
I know - not the best practice and I should have been more patient and tracked down exactly which component(s) were failing. I also should have done one board at a time with a dim bulb test in between each. Unfortunately, I did not do either of those things, and after re-capping both boards it will not pass dim bulb. Live and learn. I am a bit stumped on where to go from here, and this is where I am asking for y'all's assistance.
I've quadruple checked my capacitor specs and polarities, and my solder joints look good. What I am wondering is why fresh caps would prevent the unit from powering on safely. Now I am fully aware that I could be (and likely am) missing something that I messed up, and I will continue re-checking to ensure the work was done well. Let's pretend everything was installed perfectly - is there a world where fresh caps cause power up issues? Could fresh caps fry another component that was working prior? I guess what I am looking for is some advice on where to start looking. I plan on checking every component on both boards for any obvious issues, but any insight on what I may have done wrong or caused would be extremely helpful! Also, since I skipped the component check prior to starting the re-cap... what do y'all think may have been causing the channel imbalance in the first place? Any common culprits for something like that? I am also curious if anyone has any experience with common issues or components that fail on these 7045 units. It was in pretty great shape prior to me getting my grubby hands in there... I'd like to fix my mistake and bring this thing back to life!
Rule number 1; only change parts in one circuit at a time so you know where you screwed something up.
Rule number 2: take pictures as you go so you know where all the wires and parts go.
Rule number 3: Check the polarity markings on all caps against the markings on the board and correct the board as necessary.
You either have a solder bridge or you got a cap in backwards. If you find a cap that was backwards you must replace it because it will be damaged.
On the main caps you can measure the voltage across each cap and see if the polarity is correct. With the dim bulb the voltage will be low but it will allow you to check the polarity.
Thanks for your reply. Noted! I'm going to re-check everything and ensure there are no reversed caps or solder bridges. It seems to me that one of those things would be the likely culprit considering everything was working before. Hopefully I can get this squared away and continue on with better rules and practices.
Note rule #3. Sometimes manufacturers make mistakes when labeling the polarity on a board. You need replicate the polarity orientation of the capacitors you take out.
Edit: If you post some photos taken after the recap somebody might notice something.
Definitely noted as I move to the other boards and for any future repairs. The power supply and power amp boards don't have any polarity markings, so I am solely going off of the mounting diagrams in the service manual. Rule #2 would have been nice for this! Learning as I go.
Just to be clear the dim bulb stays on and is bright? A photo of the main filter caps would also be helpful.
Looks like a may have a bridge here between C752 and R753
Edit: I misread the diagram. That isn’t the resistor, it is bridging with C765
  • Like
Reactions: mbz
There are some good photos in the thread below if you want to double check capacitor orientation.
  • Like
Reactions: mbz
It looks like the main filter capacitors are incorrectly wired. The B- capacitor should have its positive terminal connected to the negative terminal of the B+ capacitor.
Yep, good catch! I noticed that after posting the photo. I corrected the orientation and still getting a bright bulb on the DBT.
Yep. In your photo your bus bar is going from negative to negative. In the attached image the terminals with black mark are negative.
  • Like
Reactions: mbz
I noticed that too after posting and swapped it around. Still getting bright bulb on DBT. Something else still going on. Ugh
For those following along, here is where I ended tonight. After re-checking all cap orientations/solder joints and correcting the filter caps, I checked the resistors and transistors on the power supply board and they are all functioning and in spec. I need to check the diodes next, and then go through the power amp board and do the same. Any other thoughts or tips are appreciated. Could I have fried something from having the filter caps in the wrong orientation? Both caps are testing good. I will also check the output transistors for proper function. I’m still thinking I caused a short somewhere in my work, but it won’t hurt to check everything. Another question I had is am I able to remove any boards from the unit and then power up on the dim bulb to try to isolate the short to a specific board? Or will the unit just not power up properly at all if a board is missing?
  • Like
Reactions: mbz
Yeah, that's a worthwhile approach, possibly modify it a bit by disconnecting the power rails to various stages, eg, left power amp or right power amp (if that is possible)
First I'd do a basic health check of the power supply voltages,
measure Vdc at pins
22 (+49V)
21 (+45V)
24 (+37V)
23 (-37V)
OK, voltages will be lower than spec because of the DBT and then again because the short will be dragging the power rails down
A useful approach would be to unload the power supply and see if it normalizes by disconnecting the wires at pins 21,22,23,24 (if these are wire wrap posts then do not unwrap, will find another way...) then DBT power up and remeasure voltages. If dbt is now dim then reconnect wires for pin 23 and 24, dbt power up...
edit board layout does not show pin numbers so need to identify wires from schematic
