toymanmsp
Greetings all, I'm rebuilding my 7055 but am in need of some HELP!! I am a novice/newbie to rebuilding vintage gear. That said, I have successfully rebuilt several Pioneers and Sansui's but this is my first go with a piece of SONY gear. I love the looks and particularily the sound from this receiver and am planning to rebuild it. I'm aware that this series of receivers has heat issues with the Power Supply boards. I have replaced all the caps on the power supply board, along with the two main filter caps the receiver powers on but I am getting no output from either channel which is odd as this wasn't an issue between replacing the main filter caps and testing (has output) and then moving onto the PS board??? I have not replaced anything other than the caps (I did replace the lamps with LED's) and checked and rechecked that the caps have been installed in the proper orientation (I am planning on replacing the 11 diodes, 18 transistors, 2 zeners, VD1212 diodes with 2x1N4148's on the PS board and the 3 large resistors). I am reading -1.3 mv / -1.2 mv on my bias adjustments, but when the trimmer is being adjusted there is not change to the mv reading and am unable to set to the correct 50 mv reading. My DC offset reading is way off as I'm reading a -1.9 V vs. mv's, so something is not right.
A couple of outliers, if the volume turned all the way up and set to FM, I can hear crackling in both channels, when I select AUX with an iPod I hear nothing. I did hear static/crackling when set to the AUX function with an iPod in both channels again with the volume cranked. I then cleaned the pots and switches, and now only have the crackling/hiss on FM. This was thru a pair of headphones and not from the speaker outputs.
So, I'm in need of some direction or assistance. I'm guessing that this is either an issue with the input transistors being out of spec and/or the output transistors are blown or perhaps and issue with the pre-amp? A bit of a shot in the dark. I'm thinking as a next step of testing the output transistors, but not sure if this would be an appropriate next step? Any input would be appreciated. Thanks.
