Is it necessary to cut the leg of the resistor to measure the voltage?
No. The resistor would be measured in place and with the receiver powered on. No signal, volume turned down.
I would not suggest doing this if you had not already taken similar voltage readings in order to set the bias, which you did do several times according to your earlier posts. If you do not feel capable of taking a live reading safely, then by all means don't do it.
But if you are able to do this, you can have knowledge of what is going on as opposed to speculation. If, for example, it is a 1 watt resistor, then it should be dissipating less than 1 watt. By providing the information I requested in my last post, we can determine this. From a distance and over the internet, readers here can not judge the significance of terms like "hot" and "smells"
I understand the receiver will be moving on regardless, and that is cool. Nothing wrong with keeping the wife happy
EDIT: forgot to specify earlier, but if you do this reading you would be looking at DC voltage, not AC
