SONY...STR-7055 TUNING NEEDLE BULB REPLACEMENT...HOW TO ?
OKMAN
I DO NOT WANT TO BLOW UP MY NEWLY ACQUIRED STR-7055 SONY AS I AM A NOVICE TECH DABBLER.....DOES ANYONE KNOW IF I HAVE TO REMOVE THE FRONT PLATE ASSEMBLY AND KNOBS TO REPLACE THE TUNING NEEDLE LIGHT...OR IF IT CAN BE DONE FROM INSIDE BY REMOVING THE TUNING NEEDLE TRANSPORT PLATE... OR MAYBE EVEN SIMPLY JUST REMOVE THE NEEDLE BRACKET WHERE THE BULB IS MOUNTED...?...ANY HELP IS APPRECIATED.....THANK YOU OKMAN.
I am not familiar with that particular unit but sometimes, certain brands will have their meter bulbs connected to the selector switch. Example, my Pioneer receiver will have the AM/FM tuning meter bulb turn off when not selected on radio
Don't know if you checked this out, but just something to check! :cool:
