Heat in the STR-7065 PS appears to be a feature rather than a bug (i.e., a design error), see e.g. thread 1 and thread 2.
The first reference thread mentions a hot R802; the second thread mentions the same but also that C801-C804 were replaced in a previous with 0.033uf / 600V caps. (@Phase700b)
The STR-7065 on my bench works great - power supply voltages appear correct within spec. So it's not a repair issue (I don't think), instead it's a design issue. The design issue is, I am seeking to reduce the heat level of C801-C804 and R802. My hypothesis is that installing larger components would help simply because of the increased capacity of the larger heat sinks. Thoughts?
> C801-C804: I have measured with an IR thermometer C801-C804 getting above 300degF (!). The originals are 0.022ohm / 200V mylar caps. Maybe move to large 600V film caps (like orange drops, if I can get them to fit)?
> R802: Doesn't measure quite as hot, but I think increasing its size to a 10 watt 220ohm resistor should help.
Thanks in advance for any thoughts.
