Sony STR-V2 replacement driver transistors
bsco
Good day to everybody.....hope everybody is staying safe.....I have this stereo and the one of the driver transistors and outputs are bad so I was planning to replace all the drivers and outputs mainly because they are so old.....the transistors are 2SB647, 2SD667, 2SA768 and a 2SC1826....I have found a few suggested substitutes but when searching for them in places such as DigiKey or Mouser, etc, they are obsolete and no longer available...If somebody here can point me in the right direction or might even have these originals and are willing to sell them I would gladly buy them.....Thanking everybody for any help that they can send my way....
Cheers
btw..
I've triple edited this post.... lol.
G'day I found these on a forum x-ref search (search pane top right corner) However I didn't compare to original data sheets. Meaning these are subs members have used. (these are complimentary pairs.)
2SD667 -> KSC2383Y
2SB647 -> KSA1013Y
edit: KSA916/KSC2316 for the 2SB647/2SD667 seems a better match.
Yes TIP41B or C and TIP42B or C good match
alternative used by members
2SC1826 -> MJE15030
2SA768 -> MJE15031
Btw... comparing to orig. data sheets would be a good exercise..
btw..
2SD667 -> KSC2383Y
2SB647 -> KSA1013Y
2SC1826 -> MJE15030
2SA768 -> MJE15031
Thank you very much.......
Cheers
