David_NC
I've posted about this preamp before, and I'm finally getting to the point to doing something with it. A bit of Deoxit in the pots was all that was needed to get it sounding good. Cosmetics are great, other than the two meter bulbs do not work after I shipped it cross-country, and there's a place on the top cover where something has damaged the paint. Both of those have simple solutions, so I moved on to performance - how does it sound.
My first test setup in the garage was with a QSC USA 900 (pro) power amp with around 240 watts per channel, a pair of ADS L780/2's, and a Windows 10 PC with a cheap USB DAC. Next, I put a dbx crossover between the pre and power amps so I could add an old RBH subwoofer. I was amazed at how clean and clear this original unrestored preamp is! There's a bit of noise on the tape head and phono inputs with the volume cranked up with nothing connected to them, but that's fine. I don't generally listen to input noise, and they quieten down when a phono is connected. I compared it to what I've been using in the garage - the same speakers, sub, and crossover but with a Kenwood KA-9100. I think the Kenwood sounds nice, but the Sony / QSC combo is in another league. To be fair, the Kenwood seems to need to have its controls cleaned again, and it's also unrestored. That shouldn't be much of surprise, as the Sony has better components, and it's construction is pretty amazing.
Next, I moved out of the garage into my main listening area. This area is somewhat compromised acoustically due to the layout of the room, which I'm unable to change. Still, I'm pretty happy with this setup. I normally use a Mac C31, a variety of sources, and Parasound HCA-1000A and Dynakit ST-70 powering biamped ADS M12's with a SVS sub. I replaced the Mac with the Sony, hooked it all up, and sat down to listen. There is a difference for sure. I'm not sure that I can describe it very well, though. The sound is very dynamic, there's no background noise, highs are clear, mids are solid, and the bass seems as good as ever. I doubt the Sony is as good as the Mac, especially considering it's 20 years older and unserviced. One thing I noticed about the Sony is that volume when using the phono input is significantly lower than when using a line level input. This is not the case on the Mac or Kenwood. I wonder if the Sony's phono stage's lower gain is by design or due to age. There are input level controls for every input on the rear panel, so I can work around this if it's by design, but I still wonder.
If I had to choose which pre to use in this system, based on sound, I'd have to do a lot more listening. If the decision was based on usability, the Mac wins. It's got a ton of inputs vs the four on the Sony, but mostly it's got a remote control! I'm not so lazy that I can't get up to change volume, but there are often big volume differences between songs when using streaming sources. It's handy to be able to turn it down to avoid bothering others, especially at night. Next, I'd like compare the Mac and Sony on a system that's more revealing than mine. Maybe I'd be able to hear differences. I'm reluctant to do much in the way of component replacement on the Sony. Perhaps the caps on the power supply board could use a freshening, and the main filter caps are easy to change. I'd like it to be 'safe' and reliable to use, but I'm not sure i really want to change the sound a lot. Perhaps it'll be easier to decide after using it in other systems.
I know a few here have had this preamp, and I'm curious as to impressions on its performance. I'd also be interested in hearing if it improved much with component replacement.
