Sony TA-2000F calibration
akabek
I recently recapped my Sony TA-2000F preamp. Now I would like to go through the calibration/adjustment procedures. I am hoping I can get some help on performing the adjustments with the test gear I have on hand.
For the sensitivity measurement I was planning to use a Rigol DG1022Z waveform generator, Siglent SDS-1104x-E scope and a HP 8903a Audio Analyzer.
Attached are some pictures of the preamp. I also attached page 21 from the service manual and a 46db pad to use for the phono low level check.
Under section 3-4 Sensitivity Measurement -, when I setup the 1kHz signal to the input jack, what other adjustments do I need to setup? The instructions mention setting an attenuator to 1 AC volt, oscillator output to 0.775v (0db) and the diagram shows a 600ohm resistor between both inputs.
Is the 46db pad still required for the phono 1 low level check or can I factor this in using settings found in the waveform generator?
  • TA-2000F service page 21.pdf
You probably don't really need to mess with the phono input sensitivity unless there is a problem when using a turntable.
Most of the checks are done following fig. 3-4 level check test setup from page 21 I added to my first post. That is the part I need more assistance with.
Post a picture of the back. Also one of the front before the face plate was taken off if you have it, ir just a picture of the removed face plate. I think I understand most of it as far as the setting on the preamp itself. What is the board for with the one trim pot on the end board? I'm not seeing any other trim pots.
Here are a couple more pictures. Setting up the preamp should be straight forward. What has me confused is the instructions where it mentions setting the attenuator to 1 AC volt, oscillator output to 0.775v (0db) and the 600ohm resistor before the input.
Do I disregard that portion of the instructions and just setup a 1kHz signal to the input jack I am checking?
Ok, I see the switch and trimmers on the back now. So, function 1 must be for the treble and bass settings?
And function 2 is selector to tuner for the meter adjustment? The procedures could be written a little clearer I guess.
Section 3-4 is measuring the gain in the preamp, different sections and the associated harmonic distortion. There don't seem to be any adjustments for this test but the test results will let you know if the preamp is functioning properly.
The test procedure specifies an input level for each input and to use the volume control to obtain a 1V output from the preamp (in the 1V output level switch setting). Rear panel level controls will be at maximum.
Your 1kHz signal to the input should be set by the attenuator to be the value in the table, -57dB for phono 1, for example. Instructions say with 0.775V out of the generator, use the attenuator to get -57dB into phono 1 and then use the volume control to get 1.0V output. After doing each input with its specific input level from the chart you can move on to the next procedures.
You want it set at 1khz, adjusted and kept at .775v output. Is that what you mean?
Test says set it to 0.775 and use the attenuator to drop that output to the different input levels required.
Someone is gonna need to look up 0.775V = 0dB and find what output level is needed from the attenuator to have -57, -63.7, -17.5dB. Crown has those calculators on line. Gonna need the additional attenuator for the low output moving coil phono 1 input to get the -82.2dB.
I don't think I've ever run into these kinds of tests with any of the preamps I've had.
I've had several TOTAL Marantz preamps from the early to mid 70's too.
I don't remember running across tests like that with them either in the service manuals other than maybe some simple distortion tests. I've always felt these Sony TA-2000, TA-2000F and the matching TA-3200 and 3200F amplifiers were a bit ahead of there time compared to some others. Especially with some of the features they had. I had a 3200F amplifier that came to me in a real mess. It had features you just didn't see in other power amps. The limiter circuit was interesting for one. It was tied into a power output selector.
My Sony TA-3200F just had two adjustments to make. Very straight forward.
I took a look at the TA-2000F service manual past the page I posted and the other measurements call for an attenuator to obtain the 1 volt reading on the vtvm. It sounds like an attenuator will be needed to calibrate this preamp?
It seems so. But there aren't any adjustments to be made. So unless there are faulty components, you should be ok I would think. It probably a good idea to replace the electrolytic capacitors, but if there aren't any burnt resistors, or failed transistors there probably isn't anything to worry about. Does it sound ok? No noticable distortion, etc?
All those tests appear to be tests to generate a result that can say the unit performs to spec or not. Isn't like you can make adjustments.
Run the sig-gen into a preamp set the output to what is needed on the input to the Sony.
It has a center channel output, that doesn't speak to being ahead of its time. More a leftover that Sony kept for a while.
I enjoyed the TA-2000 I had even though it came in broken right out of the box, one meter not right and the warranty repair added a hum to phono. But after the second repair the unit was right and reassembled properly. Not like a McCormack amp that had factory service and came back missing screws.
In the manual it shows a total of 4 adjustable resistors. Two to set the high and low voltage regulator and two for the right and left level meter calibration. For all the tests and calibration procedures the instructions call for the attenuator and setting a 1v signal. I was hoping I could use a feature in the waveform generator to attenuate the signal replacing the need for an external attenuator.
I took a look at my waveform generator user manual and it mentions an attenuator as an option. The attenuator they offer is fixed at 40db. I took a look at the auction site and I found a vintage HP 350D attenuator that meets the specs but for now I think I will pass on the purchase just for this task. Not to mention it would be another device that would need new components to work properly.
I was able to adjust the high and low voltage regulator and even then they are both very close to being on the mark.
I will just button it back up and run the amp and preamp in my system as is.
For anyone running a TA-3200F and TA-2000F, what speakers pair well with this combo?
I was testing the two phono sections on the T4A-2000F and with phono 1 the left channel has low volume output. Phono 2 is working great and it on a separate PCB board. I am hoping I can get some help trouble shooting the faulty component(s). The first image, PCB A Phono A, shows the left channel is the top half of the board. Should I start taking voltage readings where the diagram shows a voltage value and compare the left and right channel readings?
Did you try cleaning the switch and selector? From the picture, it looks like phono 1 is on a switch? It's kind of hard to read, the picture isn't clear enough. After that checking voltages would be a start. I had a pbono 1 and 2 on a Marantz preamp that one of the phono input had issues. It turned out to be some corrosion on the legs of a transistor. They were plugged into sockets. After cleaning the leads and sockets I cleared up with even channels again. The selector had to be cleaned also.
I did clean all the controls with Deoxit. I check voltages on the left channel and found a transistor with a leg reading 0v when it should be 57v. The other two legs were reading high voltages. I am going to replace the transistor and recheck voltages.
