Lorado
Hi all, I am a new member from Australia and I bought a second-hand Sony TA-5650 V-Fet amplifier.
I read in this forum about how to measure the V-Fet transistors, so I removed them from the amplifier , cleaned them thoroughly from thermal paste and measured them according to Sony Hi-Fi Service Bulletin No. 62, and some posts by other knowledgeable members in this forum.
The results are as follows:
Nr. V-Fet Rank # Type S-D (ohm) S-G (mV) D-G (mV)
1 2SJ18 JL-54 PNP 2.4 493 493
2 2SJ18 HE-54 PNP 2.4 539 536
3 2SK60 JL-54 NPN 2.8 560 560
4 2SK60 JE-56 NPN 2.4 555 555
5 2SK60 HC-54 NPN 2.8 554 548
6 2SK60 JE-56 NPN 2.6 551 550
7 2SJ18 HD-54 PNP 2.6 554 550
8 2SJ18 HD-54 PNP 2.8 510 507
I measured these with my Tenma DMM, which lowest range for resistance is 200 Ohms, so I think the Source to Drain resistance might be a bit high, but overall the V-Fets seem to be ok. The amp was probably repaired in the past with two different ranking transistors, but as long as it works it should be good, shouldn't it?
Next steps will be replacing the four VD1221 double-diodes (D301,303; D351,353) with 2x 1n4148 in series, with heat-shrink tubing and thermal paste on the Bias-transistors Q310,360, replacing the bias pots RT301,351 (2.2k) with Bourns 1k multi-turn trimmers, and making a list of all the electrolytic capacitors that need to be replaced.
Cheers,
Walter
Cheers,
Walter
