Sony TA-E1000ESD vs TA-E77ESD - thoughts?
msg1975
Hi. I recently purchased a Sony TA-E1000ESD as a preamp for my TA-N77ES amp and I've been happy with it. However, a friend has decided to sell his TA-E77ESD, which is the matching unit to the TA-N77ES. My OCD is kicking in, and I'm tempted to get the "matching" unit.
Does anyone have strong opinions on either PreAmp, positive or negative?
In an ideal world, I'd just listen to both and see which I liked better. But shipping across the country to test them together is somewhat cost prohibitive.
Thanks,
Mike
I am currently using a TA-E1000ESD and while I've never used an N77ES I think you can do a lot better than the E1000ESD for a preamp for stereo listening. I have mine currently driving my Classé CA-400 power amp. For whatever reason I cannot get it to drive the amp adequately. I'm running a pair of ADS L1530s and on the eq had to up the bass frequencies a bit to get it not to sound thin. Prior to this I was using a Counterpoint SA-3000. Prior to that I was playing around with a Maverick D1 DAC as the preamp and even it seemed to be much better at driving the amp. I also need to turn the volume up much more on the E1000ESD to get as much volume out of the speakers.
Who knows, maybe they just don't mesh well. I know someone who switched from the 1000ESD to the E9000ES and we both thought it was a definite improvement and I've read others disliking it for stereo use. I know you've been happy with it, but I think it's likely you'll be even happier with the N77ES.
Dan
The 77es is a regular line stage, it doesn’t digitize any signal other than digital gear connected to the S/PDIF inputs. So it will likely sound a good bit better than the 1000. It’s (the 77) also built to the hilt.
Dan
I have a E1000. If you flip down the front access panel and look over on the far left side, you will notice digital and analog input level controls. These can be adjusted to drive any amp you might have hooked up to it. Try it, you'll like it.
Let the OCD kick in. The E77/E80/E90 are known performers. You should be able to unload either pre-amps, so you are safe there.
Thanks,
Mike
Hi Mike and others.
I had the Sony TA-E77,E2000,E1000ESD ,connected to my TA-N77 and N80 but luckly I sold them all ,as the sound is RUBBISH! coming from those digital preamps.
If you are not used to an Analogue preamp sound then these would be marvellous ! For you.But the reality is not, The sound is too weak,no highs or bass at all ,as all the sound coming from a 200W pc amp is stuck inside of those crap preamps.I Just adquired the TAE-80 not to match my TA-N80 but because is two channel and not the let down prologic crap :5/6/7 etc good for nothing system .Just try any analogue preamp like my STR-7065A gem or even the STR-7055A,or the cutest cute the STR-6046A amp-preamp ... and you will see the difference! .However if you want a professional hifi sound digital converted to analogue , get if you have money by all means ,one like my Sony STC-7000 preamp Masterpiece ! What a preamp so powerfull and clear, with Bass, Treble ,and Loudness commands !
And if this connected to a QSA-2030 Quadraphonic you will be in heaven as you will have two master Volume controls,
Two loudness controls and quadraphonic sound and not double -dolby divided into 5/6/7 etc but four tracks not divided at all.
Im displaying all my black Sony 1984-90 ES system connected to my Sony APM -77W /55W speakers in Leicester at the Wigwam hifi show in Kegworth in March 2020.
After my final appearance at the show Ill sell them all but my STR-6120/6200F/STC-7000 are for keeps .
Max
The Sony guy
The problem with the 1000 is that all inputs are sent thru the DSP and then converted to analog to send to the amp. The 2000 cured this by keeping analog(phono, tuner, tape,etc) as analog and not converting them twice. Made for a better sounding preamp
....And if this connected to a QSA-2030 Quadraphonic you will be in heaven as you will have two master Volume controls...
Welcome to AudioKarma.
Regarding the quadraphonic decoder; did you mean the SQA-2030? Was the QSA a typo?
Get the matching preamp. I owned a TA-E1000ESD a while back, and never warmed up to its sound, which I found thin, no matter how much I fiddled with its controls. The 1000 is really a first gen A/V piece, designed to be hooked to a TV and VCR(s) for movie playback. I sold it on for a reasonable sum (IIRC $300), and replaced it with a TA-E77ES, much happier with the sound now. Plus, if you ever decide to sell the TA-N77ES (which command very, very high prices), you will get a handsome return if you have the matched pair.
Hi Jimbo what a nice surprise you are there just on the other side, Thanks for the info regarding the TA-1000 DSP ,to be honest the TA-1000 perfoms better then the TA-2000esd and the useless TAE-77 ,however the TA-E80 is far better but never even close to the stc -7000.
I had the TA-2000F ,nice looking preamp indeed but solid ... Weak useless thing too. just tried the TA-E90/ TA-N90 from a friend of mine ,connected to his adorable Sony SS-M9 : 300W ,4ohms fantastic ! But the same sound to my
str-6200F connected to the extraordinary Acoustic Research AR-3A king of all speakers.
The sound shoud be powerful with the Vol set at 15% and have the house rocking .
Yes the Q phonic gem is the SQA -2030 what a performer !
Just trying to bring my brothers ST-5555 from USA for the show but the insurance is too much.
Anyway are yoypu comic g to the hifi wigwmshow?
Max
There's no comparison. I've owned and tested them all. The 1000esD and the 2000esD preamplifiers are amazing pieces of technology, but ultimately toys. If you want the best 2ch performance from a Sony product, the 77 and 80 are way better in every regard and the 77 matches your amplifier perfectly. The 80 aesthetic suits the TAN-80, not the TAN-77- they look wrong together. From the phono stage to the output stage, from the inert gas-filled relays to the chassis. From a <2V output swing (1000esD) to a >12V output swing (77esD), the 77 wins hands down.
Put it this way, there are three (3) TAE-77es sitting in my collection and one (1) TAE-77esD. The others are long gone. The TAE-80es is a fantastic preamplifier, but the motorized input selector is a disaster.
Funny, I was comparing the direct switch vs non-direct the D/A equipped 77esD with one of the 77es (no D/A) only few days ago just for fun. (I do this sort of stuff) Very close, except less low level mains and harmonics in the direct position (THD+N improves). Note the THD, that is the residual of the card I was using...
Direct on
Direct off
Here's the TAE-77esD (the US model with the onboard D/A)
Direct switch off
Direct switch on
Put it this way, I tested five preamplifiers the other day out of my collection and all of them had THD below 0.001%. They were all ruler flat and they could all drive anything with levels >10V RMS. They were also all from the 1980s.
@Max cando You have no idea what you are talking about re the TAE-77es.
And for information, this (circled) is the motorized input selector incorporated in the TAE-80es. When it gets noisy (they all do), the repair ranges from difficult to impossible. It must be completely removed and dismantled right down to the wafers (silver oxide corrosion). Not a fun job. The E77es(D) uses banks of individual relays. Much better, reliable and easily replaced if issues occur.
Direct on
Direct off
Direct switch off
Direct switch on
Direct on
Direct off
Direct switch off
Direct switch on
Hi Restorer
Well done mate nice and and interesting job.
As you know we were having discussions on the TA-E77 ,1000,2000 etc ,as I always been complaining about the quality the sound no close to an analogue preamp.Well my hifi nutters! Let me tell you this:
Yesterday I went to visit a friend of mine who has a fantastic Sony,Sansui, McIntosh collection, and he complained about the sound of his TA-N77! I told him it was not his amp but the preamp ,who thought his preamp was a blessing!
At that moment I had in my car this guys: A Sony SDP-777ES digital surround processor, which I just adquired for the show at £10=$13. , then I suggested to connect to the preamp ,and to three Sony TA-220 (he was about to damp them).
Then we connected to six speakers to complete the 6 surround ( not my cup of tea at all !!) system then...
Turn the crap on :two speakers to the TA-N77 , two speakers to one TA-N220, one speaker to TA-220 central and finally one speaker to the TA-220 extra woofer.... The sound was amaizing ! It was Like hearing Asangue being realised from detention !! Fantastic !. The Sony SDP-777 is still there as my friend refused to disconnect it.
It was a coincidence? The TA-E77 is good but needs a SDP to shout better ? Who knows my friends ,time to investigate
For me? Got the feeling i need to look for another SDP-777 with wooden sideburns .
Max
The Sony guy
