Hello again, i have the final results. Iesterday i have tested the SONY TA-F6B amplifier with my PC, using REW program, the line out of the soundcard goes in to the imput of the amplifier, and the output of the amplifier witch is connected to 8R load goes trough an atenuator(for not blowing up my soundcard with 90Vpp) to the line in of PC.
Before the testing, i calibrated the sound card to give a flat response over audio range 20Hz-20Khz. This is done conecting the soundcard in loopback mode, R channel line out to L channel line in.
So first i had installed the CX171 replacement board, do the testing, then replace the board with original SONY CX171 circuit,(and re make the dc bias and current adjustments acording to service manual) and most impornant thing: with same setup, same settings, same PSU, i made the the same tests.
I want to do this way because i know of the limitations of the testing: long wires, bad shielding(i have a very noisy power supply and the amplifier is out from the metal case), not to mention that i have the on board sound card, a decent one ( 24 BIT at 192Khz ), but not professional for audio testing. In loopback mode , the THD is around 0.02%, so i have a baseline of my soundcard and wiring.
Regarding the tests , i have done two tests, a sweep from 20hz to 20Khz to see the frequency response, and THD. All the tests are done with the load conected at the output and at full power, the oscilloscope measure during tests 88Vpp at the output of amplifier. If i go over 90Vpp, the amplifier go in to clipping.
Here are the results: First, the replacement board:
So we see that over the audio domain, i have a diffrence of 0.4db ,but i see that i have an increase of signal at high frequencyes.I think is from C2 capacitor that i put for stability of the amplifier in case of overdrive at ultrasonic frequencyes.
Now the THD:
The THD at 1Khz is reported as 0.952% With is acceptable, but it could be better and i think it could be improved. I suspect the same capacitor.
Next, i removed the board i made and solder the original SONY CX171 circuit, do the trim pots adjustments to current and dc bias and do the same tests, with the same settings:
You see the sweep, i have an atenuation at higher frequencyes, but the diffrence is around 0.3db witch is ok, similar with my board but in opposite direction.
Now the THD:
Here is a big pleasant surprise! THD at 1khz is reported as 0.087% ! Much lower! So SONY original IC is better! This was to be expected! I am not an SONY engeneer!
That's why i want to do the comparison with the same setup! The service manual say that THD is lower than 0.03%, but hey, i have long wires, a onboard soundcard and a noisy power supply, not to mention that the amplifier is not shielded!
So that's are the results guys, i leave the original circuit in his place, i will not continue the improvement of the replacement module soon, maybe in some sunny day, because the client want the amplifier back and i have other things to do also.
According to Wikipedia, " For high fidelity, this is usually expected to be < 1% for electronic devices; mechanical elements such as loudspeakers usually have inescapable higher levels." So this in my opinion is a perfect usuable replacement in case of need. It could be improved, anyone could make his own improvements, i have done the start.
Next, i will keep you informed about the amplifier, i have to put the amplifier board back in the original case, and for science and curiosity(also my curiosity) i will do the same tests again but this time the whole amplifier, with tone corector and such... I am curious to see what are the diffrences in testing values.
But this in the future. Until then greetings from Romania!
Bye!
