I am about to take possession of a Sony TA-N77ES, the multi voltage version, in a few days, and I have been trying to read up on it.
In general my philosophy is to leave as much as original as possible, and hence I won't upgrade it, but rather keep as much stock as possible and only change the stuff that really needs it.
I can see I should inspect the four/six big 4700uF/80wV capacitors (C315,16,18,29) and replace the two trimpots (RT701,751) for the meters, and work out some solution to change the meter lights to LEDs that is in the same color and brightness as the bulbs.
What else should I check/replace?
http://audiokarma.org/forums/index.php?threads/sony-ta-n77es-repair-advice.766247/
Bias and offset trimpots?
Is it difficult to adjust bias and offset on this amp?
http://audiokarma.org/forums/index....g-bias-and-offset-adjustment-trimpots.523365/
