TrevorBarten
Well-Known Member
I just bought a 80es set for personal use and I am running a few checks on the amps to make sure they are ok. The bias adjustment in the service manual calls for 15mv per channel when turned on for 5 minutes. However I assume the bias will keep climbing for another 30 minutes or so. Is it expected that this number increases from the set 15mv or should I wait for it to be fully warmed up and set it at 15mv per channel? Thanks!
