Mr.Marchuk
Hello, I recently acquired a Sony TC-366 deck, and before turning it on, I wanted to check if the voltage selector/knob (located next to the power cord) was in the correct setting. Mine didn't have the protection bracket over it, and it was easy to pull out. As soon as I pulled the selector out, the paper sticker with the marking that was dried and unglued, fell off into inside the box. I had to hunt for pictures of it on Google to see how it should be set, and I think I did ok. It would turn on, and the motor worked. When I opened it up to clean and replace belts, I found the motor run capacitor leaking, and the motor gets really hot. So, I suspect that maybe the voltage selector wasn't quite correctly set?
Could someone please share with me the correct position of the label and the selector, how should it be for the US?
Thanks in advance.
Thanks in advance.
